Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Mon Oct 18, 2004 7:24 am
look up under the dash. Find the two cylindrical holes in the bracket. Find a drill bit that is a bit smaller than the bracket and go to town. For the center hole, get a 38mm (1 1/16th in) hole saw. From the inside, find the centerpoint of the embossment and drill a small pilot hole. Then go outside and finish drilling the hole.
EDIT: You'll make your life a lot easier if you have a right angle drill to do all this with.
