Auto to Manual Question
okis14
I'm getting ready to swap my car from Auto to Manual.
Where can I find a stainless clutch line that will go from the Clutch MC to slave without using the Dampener Block or whatever it's called.
I ordered the stock line that looks identical to the nismo stainless line in shape but that thing is a little short. I'm assuming this line goes from the dampener box which then goes to the slave. Am I wrong? Since I don't have those lines I've been looking for a long stainless line from the MC but can't find one. Anyone know where I can get one?
Also when I look up driveshafts in junkyards they list ABS and non ABS ones. Do those really matter for the driveshaft? I don't have ABS and am assuming that either will work.I ordered non-ABS ones so it won't matter for me but I'm just curious.
Hijacker
Car: '92 240sx Convertible
'94 F-150
ABS driveshafts are an inch shorter than non ABS shafts. There's an extra gear sensor in front of the diff on an ABS car
Adikt
http://www.splparts.com for the clutch line that bypasses the damper
SHIFTrl240
Car: 1990 SR20 Sil-80
2009 Yamaha RoadStar Warrior
2017 Alfa Romeo Giulia Ti AWD
okis: the line you have is fine, you need the clutch hardline to go from the mc to that line
they don't make stainless lines THAT long.. unless you were to get one custom made
okis14
Adikt - Thanks but that is the line I have, just the stock version of it. But I might get that stainless one since it's pretty cheap.
SHIFTrl240 - That is exactly what I need. I can't find it. Know of any places I should look?
SHIFTrl240
junkyard is your best bet.
Nolimit
okis14 wrote:SHIFTrl240 - That is exactly what I need. I can't find it. Know of any places I should look?
The Dealership. It is only about $20. :)
s13sr20chris
you could just bend the hardpipe and leave the rubber line on the end.
SHIFTrl240
Nolimit wrote:The Dealership. It is only about $20. :)
hey, if it is only 20 bucks and is pre-bent properly, go for it. i got my harline as a package deal with a bunch of the other stuff i needed from a junkyard, otherwise i would have done that
