Auto to manual question didnt seem to be addressed elsewhere
E Dogg
Car: 1997 M3 sedan
1988 TII RX-7 10th AE
1990 Ford Bronco XLT
Do you need to swap the counterweight/pulley when moving from auto to manual?
in most engines the front balancer and counterweight are setup for the flywheel/tq converter- which do not weigh the same...
dccse3k
I didn't change mine and it seems to work fine. check out courtesy nissan and see if they are different part numbers to make sure.
E Dogg
Car: 1997 M3 sedan
Not a bad idea.
the Mrs. bought an S14 that was swapped and i'm double checking everything is as it should be, because i'm anal like that lol
I usually work on FC's and they have a different counterweight for auto/manual- which is why i wondered about this.
moso
Car: 89 240sx ka24de 5spd
90 240sx ka24de RIP
Courtesy Nissan only lists 1 for the kae and 2 for the kade (one 2ws one 4ws [hicas])
