Auto to manual in a 90-94
aznxkrnxboi
Car: 240sx 91 fastback
Tryin to convert from auto to manual 5spd i need all the part list needed to start this project my 240sx is a 91 fasback 2dr i am goin for a s13 sr20det swap soon so im thinkin should i wait til i get the engine then go for a 5spd either way i still need the list thanks
All_Motor_KA
Car: 1989 240sx SE
Welcome to Nico. The red flashing button up top that says search will answer all your needs as for a parts list. And in my opinion wait until you do your engine swap. I like doing everything at one time.
1991S13
Car: '91 240sx Coupe, '00 QX4 4x4, '02 Sentra Spec V
Yes, use the search button!
I would wait until the engine swap to do the manual swap, but that's just me. Rather do it all at once than spend a lot of time on two seperate occasions. The KA transmission does work with the SR though, so if you swap to a manual now you won't have to hunt down a SR transmission with the engine. Just make sure you get the SR bellhousing.
bruinbear714
You'll need:
1) clutch hard line2) clutch master cylinder3) transmission, ecu, & lower harness4) engine/transmission plate, bell housing, clutch5) clutch slave cylinder6) clutch pedal assembly
1991S13
You don't need the lower harness or ECU.
