auto to manual conversion, experienced please!
InfamousSilvia
Car: BMW
So Im doin an SR swap with manual trany. I have a auto 95 240sx. I have all the parts for the conversion and have started it. I put the new brake and clutch pedal in and the clutch master cylinder. Well theres a computer where the clutch pedal goes, I unbolted and its just hangin out right now, Is this computer something for the auto trany setup? I am not sure what to do at this point, do I take it out, or is it something that needs relocated? Also I have the sensors and relay for the clutch pdeal and wasnt sure how to hook them up? If anyone has done this specific swap thereselves, please help me out! I am pretty sure I can get the rest of this swap completed, just hung up on this part!Thanks in advance!:help
IveBeenBad
Car: 1990 Nissan 240SX Fastback STOCK BIOTCH
pics would help...
randybunctious
Car: racing yo mama
yeah just disconnect that box you dont need it. when i did the auto to manuel on my friends car we just straight wired the starter to the ignition switch. it bypassed everything. only problem is no reverse lights and if you start the car in gear it will run over dogs, cats, people etc. but my friend hasnt made that mistake yet. the reverse lights can be made to work. there is a complete wiring diagram in the fsm which i have used to wire everything up. hope this helps
