180fan »
https://forums.nicoclub.com/180fan-u3602.html
Wed Nov 05, 2003 6:23 pm
manual should be a bit faster. yeah if you're gonna switch, might as well pull your ka and make it into a mantle piece and drop the sr in there. just as a side note, you'll need the hardline, clutch damper or a line with the loop remover (like the nismo or takamotorsports), the transmission, shifter with all rings and washers, shift boot, shift knob, clutch and brake pedals along with a drill to punch a hole for your clutch pedal. oh don't forget the gear oil and to brake loose the filler and drain plugs so you dont have a hell of a time getting them out when you've already installed the transmission.
