:: orion :: »
https://forums.nicoclub.com/orion-u7549.html
Fri Jul 22, 2005 3:11 am
Easy.
Put the stock switch ont he clutch pedal...when it's depressed, it will complete a circuit. Make the circuit GROUNDED.
Now, using a relay, wire the 2 large wires under the hood to connect when the relay is grounded, like so:
pin 30 - One of the neutral switch wires.pin 87- The other neutral switch wire.pin 86 - positive (+) wire that's switch from the ignition.pin 85 - Wire ( (-) ground)from the clutch switch.
SO when you put the key in and turn it to the first position, the one switch wires goes hot. As soon as you depress the clutch, it closes the relay, and completes the NSS circuit. And the car starts...
Easy.
- Brian
