auto to 5spd swap in my 90 240sx. whats needed
crazydaver
Car: driving mountain roads
ok i know this has been posted thousands of times but it couldnt find it. i am looking for a 240sx transmission out of a 89-94 240sx. i know i need the clutch master and slave cylinder, hardline,shifter. iv read that you dont need to swap the ecu or nothin. so does that mean it is pretty much a direct boltin? iv got the clutch master and slave cylinder already and looking for a transmission. is that all i need? plz help me,lol.
Hijacker
Car: '92 240sx Convertible
'94 F-150
I swear I answer one of these a week.
Anyways, you'll need the clutch master and slave, the clutch pedal, the brake pedal, and the clutch hard line. If you want to make it easy on yourself, you'll also want the clutch damper box and adjoining hard lines.
The auto ECU is designed to run both the manual and auto cars. If you need more information on the swap itself use the link in my sig
crazydaver
ok that helps so im making a list in my head im just gunna type it out and tell me if im missing anything, cuz i wanna get these parts from the junkyard and nissan dealership or somethin like that so, so far i got:clutch master cylclutch slave cylclutch hardlinemanual cross membermanual driveshaftif the manaul transmission comes with clutch and flywheel i wont need any of thosemanual transmission boltsbacking plates(some kind of plates anyways)is that all?
Hijacker
'94 F-150
don't forget the pedals.
crazydaver
ok so with like the pressure plate and flywheel if i get all that with the transmission and what not and ill get the clutch pedal will i need like the pilot bearing and stuff still. im trying to get a parts list thats will not have one thing missing
Newcastle82
Car: sold my s13, have no car.
Yes. You will need EVERY part associated with the clutch. That means a clutch kit. Disc, plate, throw-out bearing, alignment tool and pilot bearing. Duh =)~
