trpower7 »
https://forums.nicoclub.com/trpower7-u205.html
Sat Apr 19, 2003 12:51 am
SEARCH, for the love of god. If you want to convert it yourself, you need to read up more on the topic, and if you feel you have the technical proficiency to do such a swap you should already know pretty much all the parts you need. However, to be nice, here's a rough list1) Tranny2) Driveshaft3) ECU4) Clutch AND Brake master cylinders5) Brake pedal and linkage6) Clutch Pedal and linkage7) Hydraulic Clutch lines8) Clutch slave cylinder9) Clutch and pressure plate
