auto to 5 speed swap question
nieko
Car: 1989 Nissan 240sx
Ok i have a question you guys, whats the easiest way to do an auto swap to manual if i have both complete motors and trannys. should i take the auto transmission and SOHC motor out and drop the manual transmission and SOHC motor one right in? or just take off the auto transmission and put the manual transmission on? which one would be easier or faster? not asking about the actual swap either, just which way you guys would go about it?
cunic
Car: 1993 240sx se
switch the trannys,,,, ur lookin at so much more work switchin the motors out
nieko
hmm but its the same motor, same wiring and everything so it would just be like unbolt and unplug everything and take it out and put the other one in and bolt in and plug everything back in pretty much. except for the other manual transmission stuff of course like the clutch master cylinder and all that stuff. but thanks for your opinion, i might just do the trannys, lets see what everyone else says too
nieko
no other suggestions?
okinawa drift
Car: 89 240sx SOHCoupe
hmm, im in the same position, im thinking about just taking out the ka and auto transmission.. thowing that **** away and putting in the manny transmission connected to the new ka sohc then wire that baby up.. doesn't seem to hard.. since the current engine in my 240 is blown.. lol
nieko
hahah damn this!!! hahah i dont know what to do? but i have like 3 weeks to think about it soo more suggestions people take out the transmission by itself? or with the motor?
verSat1l3
Car: 93 S13 Fastback 96 S14 SE
I would swap the trannys with their wiring harnesses. You'll have to swap the pilot bushings in the crank and the flywheels. You'll still need to install the hydraulics and clutch after that. Driveshaft too.
I dont think all this warrants pulling the motor. Yes its a PITA to put the transmission back in but its less hassle than the little surprises you get when pulling a motor.
okinawa drift
what did you decide on doing?
nieko
i ended up just doing the transmission swap... wasnt that bad, woulda got done a lot sooner but ran into a few little stupid **** hahah but i dnt think that will happen to you. oh and 4 words! "Blind hole puller tool" ull know when the time comes aha
okinawa drift
hahhaha :P
as for hardware, did you guys use all of your automatic hardware?
i know for the flywheel you need m/t bolts...
nieko
you also need mt bellhousing bolts!
okinawa drift
ah ok, do you know the size of the bolts that mount the slave cylinder to the transmission? i don't have those
oregon
Car: 1989 240sx
I know its too late to matter, but after reading the posts on auto to manual swaps, I pulled the engine. It was sooo much easier than the frustrations I read about. Removing the transmission mounting bolts, flywheel, auto bearing was a breeze with everything sitting on the garage floor. I am down to about 3 hours by myself to pull the motor, and about 4 hours to put it back. Zero frustrations and no bleeding.
okinawa drift
yeah thats what im doing, but i can't get my hands on a cherry picker.. its pissin me off lol
