http://www.cb7tuner.com/vbb/sh...d=588
Been doing some research, seems that the 92-94 Acura Vigor are very close cousins to the 92-94 accords. My Vigor is an auto and the transmission is shot, seems to be a common problem for this car...So I would much rather swap it to a 5-speed than deal w/ constant auto problems.
I've found that list on top and that general walkthrough, I know the wiring will be off, but other than that, would you guys say that its a good list of a general 5-speed swap parts?
I'm also curious to see if I have to use the wiring harness from a 5-speed or if I can get away w/ wiring up the manual ECU using the Auto wiring harness....
Thanks for any info guys, I know this isn't really a Nissan, but my question's pretty much aimed at the general yes or no answer type of question.
-R
