ThisIsSparTTa »
https://forums.nicoclub.com/thisisspartta-u210180.html
Tue Jan 27, 2015 11:44 am
transmission bolts aren't that bad if you drop the back of the transmission to get at the top 4 first.
If you want cheaper, do it yourself. Is your time worth $2400? The price is about right considering they're experts on this and will get it done right on the first try, unlike a random shop.
I did the swap this summer, but its hard to say the exact amount of effort I put into it all because I did a ton of other things at the exact same time. It's really not that bad, I could knock one out in a weekend easily with the right parts lined up.
If you were to do it yourself, there's some areas you can save in. For instance, $200 of those parts is probably for the special Wiring Specialties Alternator harness to go from A/T EFI harness to the M/T. This really isn't necessary, and you can just splice over the wires for the reverse lights and basically be done with it, it just won't be quite as clean looking by your passenger headlight. There was some other issue I ran into with the connectors on the transmission, but I think I may have caused it.
Other simple parts like the clutch pedal you could crab from a local parts yard, etc.
Fair warning if you do it yourself, some guy from TT.net had posted a guide on how to cut in the clutch interlock switch (what keeps the car from starting with clutch engaged), and I found it to be completely wrong. I had to re-do it myself based on the diagrams in the FSM.
