zswap0429 »
https://forums.nicoclub.com/zswap0429-u213406.html
Sun Mar 11, 2018 11:12 am
Ok so I have no Idea whats going on with this car. it Idles just fine in Park or Neutral, but when it gets put into drive or reverse is sputters out.
background: I bought the car cheap because it had a bad Transmission. I bought a junkyard Trans and swapped it in. While I was at it I did a 120K timing kit, valve gasket kit, coolant bypass, and EGR delete. I put everything back together with the exception of the exhaust.
after a few setbacks like dead battery, I got the car to start and Idle perfectly. but if I press in the brake the car looses RPMs rapidly. and If I put the car in gear it dies instantly. if I pull the vacuum tube out of the back of the balance tube it is able to hold RPMs when I press in the Brake but still dies when going into gear.
this is honestly the weirdest issue Ive ever dealt with with these cars and I have no idea what to do. If this was a manual I could have figured this out. but with a Automatic I have no idea.
Please help!
