Spins »
https://forums.nicoclub.com/spins-u7278.html
Wed Aug 25, 2004 7:07 am
Yes, I know the temps in the transmission are going to be higher. I wanted to first know what the temps where coming out of the cooler. I thought of actually adding a second temp sensor before the cooler or just swaping the unit I have now to compare the readings. It would be nice to have a dual reading gauge. Input and output.Once I get a reading from the input side I can determine if I need to add another cooler somewhere. What's the ideal temp for a auto transmission? I know it has a working temperature it needs to be at. I would think somewhere between 160-190 *. Right now with my transmission cooler mounted inside the fender well area where the foglight used to be I have no way of pulling air over the cooler at a stop. The temps drop quickly one I start to move.
