auto roll up windows
bicsintegra
Car: '06 Infiniti M35
'06 Infiniti G35 Sedan (daughter's car)
'11 Ford F-150 FX4
'13 Ford Edge Sport
2020 Infiniti QX 80
recently i have noticed that my windows do not roll all the way up anymore they will roll down but in order to go up i have to hold the button. the sunroof also will not open without me holding the button. i used to be able to just hit the sunroof button and it would open all the way up on its own. has anyone else had this happen to them?
merlinq2
Car: 2007 Infiniti M35x
yes it has happened to me, there is a procedure in the manual for setting this up. I think you can search the forum and find a link
Larz
Car: 2019 Q70-L RWD
This happened to me too. I took it in to my Infiniti service guy. He started it up, pushed AND held the window button until it was completely down, then released it after the window was completely down for a few seconds. The he did the same procedure raising the window. It has worked perfectly ever since. He told me it just needed to re-learn that feature - no charge.
svard75
Car: 06 M35x
Open each window half way. Raise the window all the way up and hold the switch up for 3 slow seconds after it reaches the top. You'll have to do the same for the sunroof.
The Bodyguard
Car: 08 Infiniiti M35 black loaded custom VIPDOUT
08 Infiniiti G35 S sold 92k miles
08 Infiniiti M45 S sold 78k miles
07 Infiniiti M35 traded 53k miles
95 Infiniiti J30 sold 155k miles
Location: Cypress, TX (Houston) o.g. from southern cali (North Hollywood)!!
If you had searched the forum you would have found your answer... Never the less, you got your answer!! :bigthumb:
You can do two windows at a time (front/rear) and also same for the roof! After opening them atleast halfway, close them holding switches closed a few seconds (5 or so) then they should be set! And same for the roof... I know I'm repeating what others had already suggested but just to assure you that's the way to do it!! :dblthumb:
bicsintegra
'11 Ford F-150 FX4
'13 Ford Edge Sport
2020 Infiniti QX 80
thanks I will give it a try.
Jeremy19
Car: 2011 M37s
I just did that procedure on my 2011 M37s and it work perfectly.. Thanks :)
bicsintegra
'11 Ford F-150 FX4
'13 Ford Edge Sport
2020 Infiniti QX 80
I forgot to reply but it did work like a caharm
