QX4ME wrote:I don't quite understand what you meant. Do you mean it is impossible to make rear windows automatic like the front passenger side window? I'd think it's possible but might not be easy (or worth) to rewire and replace with an "auto" switch. Window motor "listens" to the signal from its switch. Remember the "auto" switch has total four stops and our rear switch have only two stops. The difference is in the switch and hence in the control circuit. I will try to find details in factory schematic.
I suppose I misunderstood you. I thought your question was whether you could make it auto just by replacing the little plastic button switch with one labelled auto...
QX4ME wrote:Also, if you mean 4" short on rear windows (will not go all the way down into the door), that's Nissan/Infiniti safety feature not to let young kids fall out of open windows. I remember My 94 Altima and 96 Maxima have that too. Sorry if you refer to front windows.
Actually it was my front windows that would always come up 4 inches short with the auto function.
I followed the directions on a thread to reset the auto function of it and now it works perfectly.
