auto Q?
pancho y onions
Car: 1992 240sx se
So i got the blts off the auto transmission but the dang thing wont come out.I was wondering but i doubt it. Do I have to take out the TQ converter outto remove the transmission if so how. also if thats not it can any body give me any advice to wiggle the dang thang out. Thanks.......and yes i ve serched.
DjPantsSpecR
Car: 93 Nissan MS13
92 Nissan RMS13
oh, i'm pretty sure you just forgot to remove the drive plate bolts
you have to remove the four bolts that bolt to the side of the engine block and to the bottom of the transmission. once you remove those you can remove the little metal plate. under that plate is the four bolts you need to remove, they are torqued to 35 ft/lbs, so they are retty easy to get out, it just takes forever to do this unless you have to people. one to turn the motor over by hadn while the other feels for the bolts and removes them
DjPantsSpecR
Car: 93 Nissan MS13
92 Nissan RMS13
i just read that post and it is quite undescriptive
these plates im refering to are black and thick metal. each has two bolts securing it to the side of the engine block, and two bolts that hook up to the bottom of the transmission
the metal plate im refering to is secured in by nothing at this point, and its only a cover
the drive plate is attached to the torque converter, but its also bolted to the crankshaft. it has the teeth on the outside of it for the starter to spin.
the torque converter does not need to come off, just the four bolts on that drive plate. just make sure you get those four bolts tight when you bolt it back up, or you will shake them loose as soon as you hit 5000 rpm. i even stripped one, luckally nissan has these bolts on hand and taps are cheap... and loctite... just torque everything correctly, dont do what donny dont does
pancho y onions
Car: 1992 240sx se
Yea i removed the things on the side that has 2 bolts on the block.But now i am confused on that part which side would it be on and how do you turn it to take it off. Thinks but kinda confused.
DjPantsSpecR
Car: 93 Nissan MS13
92 Nissan RMS13
you will be laying under the car looking up at the transmission. someone will turn the crank around on the engine and you will be laying down there looking in that spot where you took the little metal cover out of. eventually you will see one bolt, i think a 17mm or a 14mm i forgot, but there are four and they bolt the torque converter to the drive plate.
one person has to hold a ratchet on the crank while you loosen those nuts, and they are physically inside the transmission so clearance is real tight, hardly any room for impact wrenches
pancho y onions
Car: 1992 240sx se
oh ok. thinks just wondering are they all the same. cause i got the 89. Thanks again.
