:: orion :: »
https://forums.nicoclub.com/orion-u7549.html
Thu Jul 24, 2003 6:36 pm
Ahhhhh...
It's easy.
On the S14, there are 4 plugs under the hood for the auto - 2 are still used after the swap - They are all located right behind the fuse box.
See here:
The top one has to be jumpered for the car to start. The second one down can be left empty. The third houses the neutral position switch wires, reverse wires, etc...and fourth one is left empty.
So the wiring harness comes from the 3 connector down, leads under the intake manifold, and goes back to the transmission.
Use the black and green wires from the harness and connect to the 2 wires on the switch (it's the front switch on the transmission) - Doesn't matter what you conenct with what, you only completing a circuit.
That's it. Easy.
For instructions with pics, see my transmission swap page...it has a link on it to a wiring page:
http://www.cautioncreativity.c...p.htm
Later - Brian
