alms24sebring wrote:ok good cuz I have an S13 trans for my S14. So I can swap the auto S14 bellhousing to the S13 5speed??
not unless you can weld aluminum and measure really good
Yeah I think only a very few 95 240's were OBDII but most are OBDI
ALL S14's IN THE STATES WERE OBDII!!!
ALL OF THEM!!
Fastazz240 wrote:see thing is i dont really care about emissions im in the states that done require it Illinois and Kentucky i just want to know if it will run properly i am doing an EGR delete as well so do i need the extra sensor? and as far as bellhousing it would have to be the Manual s14 bellhouseing as the auto wont work right? what sensor is it exactly and can i get away with not using it and not have a damn CEL i hate those
your going to have a CEL..
Fastazz240 wrote:well the parts i have are as follows
s14 Clutch Pedal (just gonna trim the brake pedal)
auto to manual Line to replace hard line
the shorty Hose between old hardline to slave cylinder
oem Clutch master cylinder
11lb Flywheel
Clutch Kit (pressure plate, clutch disk,throw out bearing)
manual trans crossmember
Manual ECU for a 95 S14
guess i will just get the newer Trans like i had intended lol
hmm also read that the rear section of the DS is the same should i just find the front part or go with a solid DS?
and as far as using the auto trans bellhousing i dont think that will work
you will need the manual trans bellhousing bolts, and manual trans flywheel bolts also. you might as well get the manual trans brake pedal.. since there is one next to the car you got the clutch pedal from..
