I'm almost done getting all the parts for the swap. I was told i would need bellhousing bolts also. i found this site with part numbers for the bolts, but it said it's for a s14 trans into s14./ IIRC, all 240 transmissions are compatible, so will these bolts also work for my s13 trans? Also, is there anything different between the starter for AT and MT?
Bellhousing:
Bolts = 08131-0601A / 60mm length / 4 needed Washers = 08915-2401A / 4 needed
Bolt = 08131-0701A / 70mm length / 1 needed Washer = 08915-2401A
Bolts = 08124-0301F / 35mm / 2 needed Nuts = 08911-2401A / 2 needed
Bolt = 08124-0601F / 65mm / 1 needed Nut = 09811-2401A / 1 needed
Bolt = 08071-0251A / 25mm / 1 needed
Starter Bolts = 01121-03751 / 95mm / 2 needed
thanks ( http://www.ka24development.com....html )
