all4sho »
https://forums.nicoclub.com/all4sho-u73798.html
Sat Jun 13, 2009 4:56 pm
auto harness has nothing to do with the tps, all the trans connectors are in the lower harness with the battery, starter, alt, oil pressure.
the upper harness has the ecu, coil pack harness, ignitor, throttle position sensor, coolant sensor, temp sender, mass air flow, wiper amp, wiper motor, cam angle sensor, o2 sensor, idle air control valve, knock sensor
