nightkid86 »
https://forums.nicoclub.com/nightkid86-u34996.html
Mon Sep 04, 2006 2:38 pm
the engine should wire up pretty easily, if you check out some auto -> manual conversions that might help. The only difference is some sensors on the transmission (plus the automatic has lost more wires on it's transmission).
You will need the 5 speed metal transmission gasket/spacer thing if you don't have it already, the auto one is different. Also, the flywheels are very different if you don't have that.
I would suggest you replace the clutch while you are down there if the clutch is old, and clean out your engine bay a lot.
