got any pix of what wire needs to be cut????Import_Ant wrote:didnt work for me. you'll need to cut the speed sensor and 4th/5th gear position sensor inputs into your ECU to achieve your goal.
There are about 123789435798 threads showing S13 ECU pinouts.240sxvaj wrote:got
lmk!
thanks
Yes. Why you would want to completely remove the rev limiter is beyond me though.chrismo240sx wrote:well then thats that ha....is it possible to tune a stock ECU to get rid of both the rev and speed limiters?
No. The speedo goes from the sending unit to the gauge cluster THEN to the ECU. You're severing the link between the gauge cluster and the ECU. The 4th and 5th gear position sensors are just that; gear position sensors. THE ecu knows when you are in 4th and 5th and cuts out at a given RPM. The only other way around that is to cut the tach signal and we both know better than that.... I hope? Trust me on this, I am currently running like this and it works fine.frosti108 wrote:if u cut the 4th and 5th gear wires, dont you lose the speedo and odo when in 4th or 5th?
Not just any shop can do it. I would encourage you to do some more reading; there are only a hand ful of shops that will tune the ECM. Otherwise you'll need to get a daughterboard.chrismo240sx wrote:yes thats what ive read which is y i dont wanna do that and im seeing if the stock ecu can be tuned to get rid of the speed limiter....so again, any performance shop could most likely do this? or no....
Quote »if it does, from what year 240 will i need it from? Thanks in advance![/quote]I installed one from a 92 into my car and it did not remove my governer. Either I got lied to about it being an auto ECU or only certain years work. Please be more specific as to support your claim because there is alot of BS getting tossed around about this topic.WWJD wrote:no need to snip any wires. I got an Auto ECU for $20 and got rid of my gov.
so yea 1st off what year is ur car, and 2nd what year auto ecu did you get?WWJD wrote:no need to snip any wires. I got an Auto ECU for $20 and got rid of my gov.
i got mine out of a 92 convertible(which are all auto's), worked fine.Import_Ant wrote:
Even better, if you have the serial # from the ECU to post up that would be the most beneficial.
Damn, a 92 vert? That must be the rarest 240 ever made and your sitting here tearing parts off of it.TheOne wrote:
also yes i believe pin 32 is only for 91-94, don't know for the sohc as i've neva had a single cammer.
if ya didn't understand it, the auto ecu will not let the car clutch start.
my car is a 90' and the car I got the ECU from an 89' auto.chrismo240sx wrote:
