goofynick6 »
https://forums.nicoclub.com/goofynick6-u13220.html
Fri Apr 08, 2005 1:24 pm
Hey, I'm back to using the auto ecu. I actually went ahead and hooked up the neutral switch and that takes the place of this "mod". When I put the car into gear now, the timing changes and the idle air controller works better. If I come to a stop by just pressing in the clutch and brakes while cruising, the car comes down to a nice idle. If I do that, but put it into neutral at the same time, the car stalls. The neutral switch does help things out...when the car is in gear it changes something so that the car doesn't want to stall. So, if you have the know-how and the neutral switch on your manual trans, you can wire it up and have it work properly.
Nick
