Auto ECU MPG???
S13n310
Car: 89 S13, DD
will using an Auto ECU on a 5spd s13 lower my mpg??? After finishing up the swap i notice my car is drinking gas way more then it used to. I am almost at half a tank after 2 days doing my normal driving when pre swap I would only be a little less then a quarter. I tend to maintain a low rpm while driving, i am not speeding or raising my rpm high so i doubt its my driving... any comments anyone?
Fastazz240
Car: 1995 Nissan 240SX
93 Nissan Vert
95 vHardbody 4X4
i noticed that the auto ECU runs a lot ritcher than the manual one for some reason not sure as to why but it was that way on my s14
corn322
Car: 1993 240sx
It shouldn't. I get the same MPGs in my S13 with either ECU.
S13n310
Car: 89 S13, DD
wonder if this is one of those things that vary by car... really killed my day to watch my gas disappear... i might try switching the ecu i guess :/
biggie
Or you are driving it harder because it is now 5spd?
S13n310
Car: 89 S13, DD
biggie wrote:Or you are driving it harder because it is now 5spd?
nah... because i see it eating gas im not stepping on it nor letting it reach high rpms...
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
the fuel maps are slightly different and autos do run a little richer, but I wouldn't say it EATS gas. did you lower your idle to 800-900 from 1100? The auto has a higher idle in neutral without a load on it.
240nessx
Car: 93 240 Black Hatch
when i use to cruise with my 240 as auto it would be around 2600-2700 at 70, and now its 3200. i dont see it making ur engine eat as much gasas u say it does, but now that u dont have a torque convertor to lock to drop rpms, ur car will be driving at higher rpms when cruising then when it did as automatic.
samxini
Car: '95 240sx w/Kouki conversion
240nessx wrote:when i use to cruise with my 240 as auto it would be around 2600-2700 at 70, and now its 3200. i dont see it making ur engine eat as much gasas u say it does, but now that u dont have a torque convertor to lock to drop rpms, ur car will be driving at higher rpms when cruising then when it did as automatic.
^ That's what I was thinking. I noticed a big difference in rpms at different speeds as well.
Oh well, gotta pay to play I guess.
costa_rican13
Car: 1993 s13 coupe
why not get a 5speed ecu? thats what i did. but i may switch to my auto ecu to remove my speed governor. :)
but i also thought that the autos have a leaner fuel map??
94_240sx
Car: 94_240SX
I got rough idle when I used manual ECU, so I kept auto ECU when I did the swap. Gas mileage was significantly improved after the swap.
breadbox
89 Koop
84 720 4x4KC
well in the case of SOHC's you can use any ECU made for a KA24e on a 5spd. I have a few 200sx ecus that had ka24e but also had consult wired stock.
costa_rican13
Car: 1993 s13 coupe
94_240sx wrote:I got rough idle when I used manual ECU, so I kept auto ECU when I did the swap. Gas mileage was significantly improved after the swap.
really? looks like i'll be switching back then. hopefully i see the same.
darens13
Car: '93 240sx, '90 chevy 1500, '49 dodge pickup
i get around 25-27 with my 5 speed with auto ecu. no complaints about fuel economy from me.
TheRealNap0le0n
Car: 1998 q45
i knocked out 28mpg with my 5spd w/ auto ecu
costa_rican13
Car: 1993 s13 coupe
omg... yep switching first thing in the morning!
costa_rican13
Car: 1993 s13 coupe
so i swapped my auto ecu back in. and i went from a 700-800 rpm idle to 14-1500 rpm idle. wtf?
TheRealNap0le0n
Car: 1998 q45
just re-adjust the idle
TimTurboZ
Car: 95 S14 w/RBXX... 65' Mustang GT
He meant gas mileage went up when he did his 5spd swap I believe. As in- he did a 5spd swap w/ a 5spd ECU and had a poor idle switched the ECU back to his auto ECU and it fixed his idle, after driving with the 5spd he noticed a mpg increase.
He was stating that going from auto to 5spd regardless of ECU he saw a MPG improvement oppose to you seeing worse results.
Your Fuel return line leaking lol, I'd make sure you didn't do something that could be making you lose this fuel while u did your swap.
costa_rican13
Car: 1993 s13 coupe
TheRealNap0le0n wrote:just re-adjust the idle
i did adjust it. and i screwed the iacv srew all the way in and it didnt even change but if i unscrew it then the idle raises 1500+ rpms.
costa_rican13
Car: 1993 s13 coupe
TimTurboZ wrote: He meant gas mileage went up when he did his 5spd swap I believe. As in- he did a 5spd swap w/ a 5spd ECU and had a poor idle switched the ECU back to his auto ECU and it fixed his idle, after driving with the 5spd he noticed a mpg increase.
:facepalm: ofcourse. lol
S13n310
Car: 89 S13, DD
havent had a chance to jump back on the forum but after driving it for a while it looks like its back to normal... first half of my tank was eaten in the first couple of days but fell on e today (filled up last sat) and did some heavy driving. So looks like its normal... i dont know if things had to settle or what but definitely saw my mpg go up in the last few days. thanks for the info, the auto ecu seems to be working fine in the car, i do notice the higher rpms, im im a little above 3000 at 70.
