Auto/Econ Options?
VG30DE
Car: 1993 Infiniti J30
Just wondering what the differences between the two are, and does the Auto option really use a lot more gas? Does the Econ turn the AC on, or just blow outside air when it's set at 65? Just wanted to know more about the both.
I can't seem to have the Defrost only on, only when it is in the Auto mode. On the Econ, I can only get the floor/defrost option, not just defrost.
I mean is it better on gas to have Econ on with a higher fan speed, or the lower fan speed and Auto?
I do a ton of driving for my job, just trying to figure out what makes a difference.
Any information about this stuff would be great, thanks.
driverdriver
Car: NICO's longtime resident Canuck!!!
Auto will come on and go off to maintain a preset condition.
Will work as long as temp sensor is not blocked.
Econ is basically manually set your temp conditions. You control it.
I personally prefer auto.
puck
Car: 1997 Infinity J30
With Auto, the climate control is on with the benefit of having the air conditioner on. Gas mileage will suffer due to the air conditioner being on.
With Econ, the climate control is still on, but without the benefit of the air conditioner. Obviously, if the temp outside is 90 degrees and you set the temp to 65, climate control will not work successfully, you'll just have a lot of hot air blown your way.
The reason auto is switched on with defrost is the defroster requires the air conditioner to turn on. This is true of most cars.
You can turn off the climate control and use manual. With manual you control the fan speeds and, I believe, there is no attempt by the car to regulate the temperature.
If you want to optimize your gas mileage, you'll want to drive with econ on, which I generally do with lower and mild temperatures (unless I'm using the defroster, of course). Once the outside temp gets over 80 degress I'm usually using auto.
You'll have to balance your desire for comfort vs gas mileage according to personal preference.
VG30DE
Thanks alot, great info
