M56Cruizin »
https://forums.nicoclub.com/m56cruizin-u184518.html
Fri Jan 18, 2013 11:08 am
Anyone know if there's an option to change the automatic door unlock feature to unlock the doors when the transmission is place in park, instead of the default setting of unlocking the doors when the engine is turned off?
Here's the instructions I've seen:
To deactivate or activate the automatic door lock system, perform the following procedure:
1. Close all doors.
2. Place the ignition switch in the ON position.
3. Within 20 seconds of performing Step 2, push and hold the power door lock switch to the LOCK position for more than 5 seconds.
4. When activated, the hazard indicator will flash twice. When deactivated, the hazard indicator will flash once.
- When the automatic door lock system is deactivated, the doors do not lock automatically at 15mph.
To deactivate or activate the automatic door unlock system, perform the following procedure:
1. Close all doors.
3. Within 20 seconds of performing Step 2, push and hold the power door lock switch to the UNLOCK position for more than 5 seconds.
- When the automatic door unlock system is deactivated, the doors do not unlock when the ignition switch is placed in the OFF position.
