auto a/c lights
VG33QX4
Car: 2000 Infiniti QX4
does anyone know what bulbs are used in the auto A/C for 2000 qx4? mine are pretty dim and need to be changed if possible. im not talking about the LCD i am talking about the auto econ, fan speed buttons.
the Radio is all LEDs right? you would have to de-solder and re-solder
the cig lighter and 4wd lights are what size and changeable? thanks
VG33QX4
i found it never mind
27545-1w600 is the oem part number
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
The buttons use 12v microbulbs, which you can find at Radio Shack. I replaced mine with said bulbs and the bulbs were slightly too tall so the bottom of the button clips the bulb glass, resulting in a bit of stickiness in the buttons, but after some use the buttons seem close to stock bulb's smoothness (except A/C which I don't toggle on/off nearly as often as Circulation, but I'm sure that one will loosen up as well). The actual lighting for rest of the unit are #74 bulbs, which I replaced with tri-LED high power LEDs.
VG33QX4
so you are saying that the 4wd and cig lighter are #74?
Towncivilian
VG33QX4 wrote:so you are saying that the 4wd and cig lighter are #74?
No. I don't have a cigarette lighter and my PF is 2WD, so I don't know which bulbs either of those use. I am talking about this:
