OFS37 »
https://forums.nicoclub.com/ofs37-u133213.html
Fri Jul 03, 2009 8:59 am
So I thought id do one of these. Car is pretty simple so far after purchasing it bog stock which was what I was after. Its a legit 97 Type x SR and all.
The day I bought it.
Got come Coilovers.
Then an OS Giken Super Single Clutch.
Both installed along with an Pivot Headlight Controller and Carbon Rear Garnish
So far so good but some stuff rocked up.
The Parcels:
Parcel One containd One 18x9.5 +12 Cr Kai, URAS Subframe Pine Apples, URAS Soild Gear Box Mount, URAS Soild Shifter, TEIN Tie Rods with Spacers, TEIN Tie Rods Ends.
Parcel Two contained One 18x9.5 +12 Cr Kai and URAS Catalouge
But on closer in spection there is a little scratch and a slight flat spot on the wheel, this could of happened in freight somewhere and its small enough not to really worry about and they are only for the rears so all good still.
Last but least Parcel Three. Now this is what im really excited about GP SPORTS SUPER KNUCKLE Kit!!! Containing the pair of Knuckles, little bolts and a Rack spacer with a spacer for that spacer, stickers and instructions in Japanese.
All together now,
So here we have the SR Crossmember and mount and URAS Mount and bits and pieces.
Before:
After:
Done:
Next was the URAS Solid Shifter, Stock next to URAS.
Done:
And then.
So... Im still awaiting seat rail and extra Bride seat cushions to arrive then the seat will go in. Also soon to sort out my brakes then I can do my 5 stud conversion and run my Cr Kais.
Ive got heaps of parts left over from my old SR20 R32 4 Door Build that will find its way onto the 180 when the time comes, should be alright... I hope.
