BenKenobi »
https://forums.nicoclub.com/benkenobi-u123174.html
Tue May 19, 2009 6:09 pm
well, the slide hammer worked.. after about 15-20 good whacks the hub came off along with one of the inner races... Wheel bearing stayed in there though ... At that point, in a very controlled rage, I took my hammer and started hitting the wheel bearing, which made it rotate a little. So I'd hit it enough to rotate, spray some PB blaster, hit it to rotate the other way, PB blaster, repeat a few times... After a while, I got enough of a gap to work my chisel in and popped it right out!
Now I just have to get the race off the hub. Bugger is *ON THERE*.
