This is as far as i've gotten with it, too scared to dig any deeper lol
if you're lucky, this could work, but if you're not, the superglue could permanently glue whatever is stuck onto the aux jack. if that happens, the only way to fix it would be to then take the stereo out, disassemble the stereo faceplate, remove the audio jack from the circuit, and disassemble that small black plastic audio jack to try and break the glue or resolder a new audio jack onto the stereo circuit boarddisfunctions wrote:put a little bit of crazy clue on the end of something skinny that would fit in there and then let it stick and then pull it out...
