Two Fowty »
https://forums.nicoclub.com/two-fowty-u120229.html
Thu Apr 23, 2009 3:31 pm
Alright, before you flame me about being on the wrong forum, or searching, I assure you, I tried both. No one is responding on the other forum, and my answer isn't anywhere to be found, so I said what the hell, I'll try this forum.
Alright, I've got a Kenwood KAC-5203 head, alpine speakers all around, a Kicker amp, and 2 hifonics 12's..
The problem, is my headunit will constantly reset and I cant even use my system cause it will just constantly do it, read on.
I've checked all my head unit wires and they are all connected fine. The power/ground/remote wires are all connected fine.
I unhooked my amp and subs and it still does the problem, but I noticed it only does the problem at a certain position that the key is turned. I put key in, turn it one notch and the dash clock lights up a bit, and the stereo turns on. At this point, everything will work fine for as long as I know of. BUT when I go one more notch, right before turning engine on, and all the dash lights are red, this is where it just keeps reseting.
Also, it will reset when I crank my stereo up to start bumpin. And once it resets once, it will constantly reset, and wont stop until I turn it off, or get out of the 2nd notch.
I'm running 4 gauge wires and they are efhin big, hardly and don't even really fit into the amp. Not sure if that relates to the problem, but I figured you should know.
Please any help would be great.
