Silvia2b »
https://forums.nicoclub.com/silvia2b-u2470.html
Mon Mar 07, 2005 9:17 pm
I am not going to harp on the fact that this is in the wrong forum subgroup, but Like "I wannaS15" said you may be running high level input to a low level designed input on the factory amp. This mistake can greatly increase level of distortion and clipping which is ruining your speakers. The truth is more speakers are damaged by underpowering them rather than having too much power. The reason is that amps that have much more headroom than the lower powered amps require a lower level of gain setting that is required for a particular volume will have much more clean and loud output from the speaker. Hope you can resolve your issue and we'll try to help, just post this in the car audio, entertainment, and security section so we'll see it sooner.
