All installed and setup! Sounds absolutely perfect. Just the amount of bass I was looking for
it's almost too much sometimes.
Had to be the easiest thing I've ever done to this thing.
Here is how to install a powered subwoofer in a Nissan Pathfinder with a BOSE headunit. *Note that I kept my stock headunit and everything that goes along with it. All I basically did was add a Sub.
Anyways, the sub I used is the Sound Ordnance B-8P. Very very nice unit. Build quality is definitely on par with the higher grade units. As is sound quality. This thing POUNDS. At $171 Shipped to my door in literally 24 hours, how could I go wrong. So far I have no regrets.
It has four white LED's built in that illuminate the inside of the box. They are controlled by a tiny little on/off switch.
I purchased a $29 8 Gauge wiring kit. Came with all the essentials for wiring an amp. Although i didnt use the RCA jacks, all the other cables that come in those Kits are definitely handy.
Wiring and routing the Mian Power cable was very easy. Just simply remove the two nuts holding the clutch plate cover on. This little doo hickey is located underhood on the driverside of the firewall right beside the brake booster. You cant miss it, there are two little bolts holding it on.
Anyways remove that, drill the appropriate sized hole and pass your power cable through there.
Routing the cables is very easy aswell. Remove the kickplates on the driverside front and rear doors. Make sure you lift up evenly so you dont break the clips. Route the cable underneith the carpet so they are out of sight.
Thats the easy part. Wiring the sub to the existing speaker wire is also easy, just a tad more difficult. Remove the driverside trunk trim. To do this lift odd the weatherstripping near the tailgate and rear driverside door. You will see where the trim piece is that you are removing. Be careful not to break that small little white tabs holding it on. It is a very large trim piece.
Once you have remove the trim, go ahead and unplug the main harness that goes into the Bose amplifier. The two wires you will be splicing into are the Light Blue and Pink wires.
Once you have tapped into those wires, route the two wires to where you will need them to be so that they can reach your sub, but still have a little bit of slack.
The remote turn on cable is very easy. Simply find the fuse for your rear wiper motor. It is located under that little coin holder underneith the dimmer switch. Give it a good yank and it will come out and expose the fuse panel underneath.
Adding the ground cable is also very easy. Underneath the cargo carpet there are a bunch of bolts. Remove whichever one is best for your situation and voila, you have a ground.
Sorry if this writeup is all over the place, not too good at this whole tutorial thing yet. I will post much better pictures tomorrow!
