WCCBaLLeR »
https://forums.nicoclub.com/wccballer-u43179.html
Wed Aug 16, 2006 6:42 pm
I upgrade my alternators, change the battery up front, add at least one in the rear, and then add capacitors for each amp. It may sound like overkill but you can never have too much current running to the amps. You would be amazed at the difference in sound between a stock charging system and a car with it done properly.
As for your car, i doubt you will need anything. If its just a sub amp then you should be fine...at night with the winsheild wipers on, a/c pumpin, headlights on, and system bumpin you will probably have some dimming of your interior lights but nothing major.
Chad
