Kolk1 »
https://forums.nicoclub.com/kolk1-u53942.html
Mon Jul 02, 2007 4:50 am
I personally did not use a harness and just did what they call a hard wire. At the time of my install, no wiring harness was available. I just used T Taps and tapped into the wires on the back side of the factory harness. That way if I ever decide to put the factory head unit back in for some odd reason, the factory plug is still there unharmed.
Im not in the mood to take out my headunit right now and make a wiring diagram, but I just checked my source for all wiring diagrams, and they seem to have a diagram now up for the Versa.
I have NOT checked this, so if you use this, please double check.
Wire: Color: Polarity: Location:
Radio brown + radio harnessRadio Ground (chassis) -Radio Ignition lt. green + radio harnessRadio Illumination orange + radio harnessFactory Amp Turn-on brown (subwoofer amp) + radio harnessNotes: The subwoofer signal wires in the radio harness are red - green.Power Antenna N/A LF Speaker +/- white - brown +,- radio harnessRF Speaker +/- green - lt. blue +,- radio harnessLR Speaker +/- purple - red +,- radio harnessRR Speaker +/- lt. green - gray +,- radio harness
