I have the system wired with a dual amp wiring kit from crutchfield. I have a power wire from the battery going to a distribution block, then 2 power wires from the block to each amp. The ground is set up with 2 ground wires going from each amp to a distribution block then to a good ground. I then have 2 power control wires going from the amps to the stereo. These two wires are spliced together into the power control on the back of the stereo deck.
The aftermarket harness for the stereo deck uses the power control wire to power the 2 stock amps, but it will not power my amps. When I disconnect one amps power control the other amp has lights that start to flicker but it will not turn fully on.
Cructhfield says that I may need to wire in a relay, because the stereo is not supplying enough current to power the amp. I tried this and it did not work. I also tried wiring the amps power control wires to a 12 volt source with a switch, but this still did not work. I also tried to wire one amp to the power control of the deck without wiring the harness to it but this even didn't work, and this is how your supposed to do it???
Also, I noticed that my power wire coming from the battery has 12 volts when not connected to anything, but when I connect it to the distribution block it goes down to 8 volts, I'm not sure if this is a problem. I am completely out of ideas and can't figure this out. Any ideas on what could possibly be wrong.
PS: all fuses are good and the grounds are good. The only questionable thing is the power wiring dropping voltage when hooked into the distribution block.
