audio help
Nissan 350z / Nissan 370z general community discussion forum
jabber87
Car: 2003 Touring 350Z 6MT
Ok, so heres the deal. I was driving along one day and realized that my driver side door speaker was not having any sound coming out of it... The strange thing is that it sometimes comes back, sometimes when do a turn or hit a bump, but then it goes away again. The sound system is the stock BOSE sound system that came with the car (2003 touring). Another thing is its only an issue with cd player in dash... Haven't tried the tape deck, because i never use it...
Anyone have any ideas on how to fix this? Appreciate the input.
Modified by jabber87 at 7:53 PM 8/6/2007
joe603
Car: 2014 Durango R/T
First, it sounds like your speaker has a loose connection, either on the speaker or on the amp. Check the amp first, it's easier.
Second, be more specific on your CD player issue. The 03-04 head decks are known to have problems. Usually they have an error code pop up. The fix is to take it to a dealer, or pull the deck and send it to a shop to fix it.
http://carstereohelp.com/infiniti.htm
jabber87
joe603 wrote:First, it sounds like your speaker has a loose connection, either on the speaker or on the amp. Check the amp first, it's easier.
There is no error code, just the speaker works intermittently. The deck still work, works, but sound doesn't come out from the speaker all the time. How do I get to the amp? Door panel seems like a pain to take off.
Return to “350z / 370z Discussion”
