Touchdown038 »
https://forums.nicoclub.com/touchdown038-u3917.html
Thu Apr 17, 2003 7:11 am
If the power cable is long enough, you could try re-routing it. I heard that if you run it too close to the ECU, you might get interference.
Also, when you routed your battery cable to the trunk, did you have to drill a hole into the firewall to run the battery cable through? Because that's what I ended up doing because I couldn't find a better way through.
