Broadfield »
https://forums.nicoclub.com/broadfield-u46569.html
Fri Sep 21, 2007 5:20 am
I don't disagree with you on the fact that the OEM speakers are sometimes worthless, but the reality is that not everyone jumps in and replaces the entire system. A lot of customers like to start out with the headunit, then add on from there.
So by your reasoning, if you keep that OEM radio which limits bass output, then when you add your fancy new speakers and amp they are not even going to receive a flat full range signal.
I'm saying either replace all of it... radio, speakers and amp or keep OEM radio and use a Clean Sweep, new amp and speakers.
Modified by Broadfield at 8:31 AM 9/21/2007
