Well, if you really want it loud, you'll need to upgrade your charging system, as in, new high amp alternator.
Amps x volts = watts. So, if you want 600w to your sub, 600w/13.8v=43.5amps and that's if the amp is 100% efficient.
Ported vs. sealed. This is a debate that's way old and way too complex for this thread, but suffice it to say, going ported will give you more output at and above the tuning frequency than a sealed enclosure.
Sealed is so easy though. You build a box (ideally with a Q or .7-.8), put the sub in it and you're done.
Ported you have to figure out box volume based on what frequency you want, and then figure out port size; Too small (cross sectional area) and it'll cause chuffing and compression, too big and the port is rediculously big which eats up too much box volume and drops your 1st port resonance too low.
***Warning, I'm going to sound like a salesman below***
If you want loud and want some attention, there are so many choices/options out there for subs, but I would highly recommend looking at Acoustic Elegance. Their subs are made in the USA with the majority of all parts (including adhesives) sourced from the USA. I have talked with the owner and transducer engineer personally.
I also own a couple of their lambda woofers and they're top notch, so is customer service. Because they're built in the USA, they're also rebuildable if you happen to blow one, which will be rather difficult. I was told by the owner that you can plug the AV15h subwoofer into a 15A wall outlet and it'll be fine. He didn't tell me for how long, but alluded to at least a minute.
Their 12" is 229, their 15" is 249 and I would recommend the 15" (AV15h) if you want attention. And, because they're all built in the USA, you can have a custom logo, your screen name, etc. on the dust cap. Or at least that's what I was told by the owner.
http://www.aespeakers.com/shop/catalog/
Testimonials have put it in the same league (sound quality wise) as the TC-Sounds LMS Ultra and RE-XXX. Both have an MSRP over $1500.Because of their excellent sound quality and power handling, they're being used in some exotic home subwoofers.
That rectangle thing in the middle of the sub is an active cooling air vent.
Classy
***ok done with the salesman***I swear I have no affiliation with AE and get nothing if someone buys something from them. I just really like their products.
