Two-Forty »
https://forums.nicoclub.com/two-forty-u2538.html
Thu Dec 12, 2002 4:35 am
the Stinger is rated at 16 volts nominal and 20 surge, while the audiobahn is rated 24 nominal and 30 volts surge.....anyone know if this is output from the cap or what? In other words, explain to me what the deal is with that.
x volts/x surge= number of volts which is constantly feeding your thump, surge is when the thump is needing of extra power, which it flies all the way to x number listed. What cap does it this:
When you are using high powered subs and amps, it's going to need more power feeding the thump, hence when you don't have a cap you might see that your lights dim when a base note hit. Cap charges up and when your amp needs the extra boost it sends the extra power.
When installing caps don't 4get there is also a remote turn on wire, that taps onto the blue wire of your amp.
