Audi LED Light strips!
All things Altima Coupe.
RLee
Car: Nissan Altima Coupe 2008
Anyone knows if the LED light strips will fit on the stock bumper for altima coupe?
PHENOMenalVinyl
Car: 08 altima coupe 2.5 mt
We use oznium led strips mainly for that look which ones r u talkin bout
dangeris
Car: 08 Code Red 3.5
08 BMW 328xi Coupe
90 300ZX 2+0 NA
Yes..it will fit. There are several guys here that did it, Toxik comes to mind of one of the guys that did it. If you're planning on doing that, go the side emitting LED strip. They are flatter and would probably provide you with more clearance then the flexible LED strip that is normally used for this application.
RLee
How many foot or inches should I order?
RLee
Which color is good if i have a blue altima coupe? warm white or cool white?
dangeris
08 BMW 328xi Coupe
90 300ZX 2+0 NA
I'm assuming that you will be using this only at night so get the cool white. it's brighter and can be seen in both day and night!
RLee
Thank you!
dangeris
08 BMW 328xi Coupe
90 300ZX 2+0 NA
Your Welcome and BTW..Welcome To NICO!
PHENOMenalVinyl
RLee wrote:How many foot or inches should I order?
depens where ur putting it if its under the headlights by the bumper the one darryl said are perfect BUT i dont think 12 in is suffieciant bc i bought a diff set of leds and they were 19in n i cut off 15 leds which was a couple inches long sooooo overall i think 13 or 14in is the exact measurement of the underside of the light.....try measuring it
if u really want something kool ude be the first to get these ima make a post in a minute about it ill link it to here after i make it
RLee
How many foot or inches of LED Light strips did you put on your car? (under the headlights)
dangeris
08 BMW 328xi Coupe
90 300ZX 2+0 NA
Yeah I believe you'll need 12" but measure to make sure. for the flexible LEDs they come in 9.5" and 19" lengths...not 12" hence why Phenom mentioned it needed to be cut. But I'm pretty sure 12" is the perfect size you'll need.
RLee
So, I just buy a foot of Side Emitting "Headlight" LED Strip for each side right?
PHENOMenalVinyl
RLee wrote:So, I just buy a foot of Side Emitting "Headlight" LED Strip for each side right?
yea a foot should be good but it wont cover the whole headlight
in case u want to see the ones i was talkin bout but there mad $
http://forums.altimas.org/zero...d=249
dangeris
08 BMW 328xi Coupe
90 300ZX 2+0 NA
FAIL on the bad link Matt...it goes to the main page of the 1st gen
Here's the right link
Bmore-coupe
Car: 08 Altima Coupe 3.5
PHENOMenalVinyl
Bmore-coupe wrote:
I'm so confused again I gotta go on here b4i do lol
ESP
Car: 2008 SexyBlack A/C
Why you.........................
I learned from my last time to always check your links before I click 'em...
dangeris
08 BMW 328xi Coupe
90 300ZX 2+0 NA
well hey..can't say I'm not still trying...
PHENOMenalVinyl
werd i never click those damn links now lol
LongBeachCoupe
Car: 08 Altima Coupe (RIP Hurricane Sandy)
2005 Lexus RX
Welcome to the club!!!
http://forums.altimas.org/zeromain is the link you should bookmark!
All the info here is in its proper section (for the most part)... Please try and post in the correct area!(this type of discussion is in the "Interior/exterior" Section.... take a look over there, all the answers are within!
The search button works too, and we are always here to help you out! (again post in the right section if you can, if you arent sure, dont worry theres no beatings issued!)
