smocan »
https://forums.nicoclub.com/smocan-u33734.html
Sat Mar 01, 2008 10:55 am
Well you got new springs and i'm assuming you installed them and want to set preload again correct?
All you do is hand tighten the top collar until it is stug against the spring, then take the collar wrench and crank it about 3-6 turns (depends on coilover, but it should keep the spring from moving or wobbling). Then do it to the others, make sure to measure the front with the other front, and rear with the other rear to make sure they are close. Then finish it up by locking the top collar in by tightening the collar just below.
