krash wrote:They're definitely KA mounts. I guess its not a big deal. I know a lot of people were saying it will move the engine up (z-axis), I guess I didn't realize that means it will put the trans at a slight tilt and cause some other moving around.
Didn't want to put them on the opposite sides because of the little heat shield on the driver's side mount. Anyway, thanks for the input guys! hopefully nothing explodes. I was mainly worried about leaking gear oil from the yoke
If the yoke doesn't engauge as much as you think it should, I'd be more worried about it twisting.
Like a cheap socket or wrench will do if you have to use it in a position where the drive doesn't go all the way in, for example.
