mbmbmb23 »
https://forums.nicoclub.com/mbmbmb23-u19119.html
Wed Oct 28, 2009 4:36 pm
Full time? Haha....far from it........I have Nistune, an Eprom reader/writer, and a UV eraser. I bought the reader/writer and a bunch of erased 128 bit chips on ebay to pull a tune off a tuned ECU I got and tweak it for my setup...originally for chips in my ECU...and now...for pulling tunes for use in Nistune....thus I have like 25 used, blank EPROM chips I have no use for. Once these chips I bought are gone, then I'm done doing this. Once again, let me reiterate...I bought this reader/writer to pull tunes off tuned ECUS...to use personally. I am not a tuner or tuned chip seller....just a tune downloader...slight editor....and eprom burner.
Once again, I dont "TUNE" chips! I have a very basic understanding of how the nissan computer interacts with these ROMS, so.... all I'm willing to do is change Maf, injectors, speed cut, rev limit. I dont touch any of the maps as I'm not a tuner and take no responsibility for anything that happens with any chip I send someone. I'm basically doing a chip or two as a favor for a few kids on this board so they don't have to pay someone $100-$300 to make a socketted ECU work with different injectors and maf. If you install a chip I mailed you and your car bursts into flames and melts.....I offer my sincerest condolences only.
There are 2 base tunes I can use.....OEM stock.....or... an "Impul tuned" chip set up for stock Maf/Injectors. On both I just change the Maf/Injectors/remove speed cut/raise rev limit.
The Impul tune is a "factory upboost" tune from an ECU I traded a kid on this board for. In Japan factory upboost usually means fairly high octane gas and raised boost on stock turbo.....pod filter, exhaust.......MAYBE SR turbo.....therefore....use this chip at your own risk. You probably will still need an SAFC to fine tune. If you have a different ROM that was set up already and are looking to change maf or injectors, email it to me and I will burn you a new version after these changes.
Anyhow, thats that. Also, I currently have 2 part time jobs and work 70+ hours a week....and I check my email a few times a week. The email I've given on here isnt my primary email...its my junkemail.... so if I'm slow to respond to your email or the chip I send takes a while....I apologize but be patient. I offer no guarantees these chips will work for you......only that it MAY work better than what you already have...which may be nothing.
-M
Modified by mbmbmb23 at 11:04 PM 10/28/2009
Modified by mbmbmb23 at 11:06 PM 10/28/2009
