Attn: Dennis
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Dennis...
Could you have the guys at T3 email me the service records to my Q... [email protected]
VIN: JNKNG01D8RM261697 (i think, thats from memory.)
Others... Please dont reply, thread will be deleted by this time tomorrow...
Q45tech
Email? You will have to deal with Doug directly. Not sure they [customer bills] are formatted correctly for an email transfer. Snail mail might work better or just FAX. I'll see if they can be transfered to a Word file.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Certainly they can be scanned into Acrobat or just tif files and emailed. Fax is so eighties.
Then there is copying and snail mail.
Q45tech
That's what the independent auto repair business is ------ so 80's.Anyway business records are Confidential so there is almost never any need to send them to someone else who is a non customer, without a subpoena.
The records are the private property of the customer not the car, you can get in real trouble releashing other peoples financial transactions and data.
Q451990
T3 has definately put their resources into good techs and repair equipment - not the physical plant. It's adequate, but definately "80s" - maybe even 70s?
I'll take "80s" over dealership prices and crappy quality service any day!
Heath
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Q45tech wrote:The records are the private property of the customer not the car, you can get in real trouble releashing other peoples financial transactions and data.
Hence it would be better for Fred to obtain them (what happened to his copies?) and forward them to you.
The same reason Infniniti Customer Service won't give just anyone the service records until the new owner is registered with them.
elwesso
2007 BMW M Coupe
So if Fred gave his consent, then you could just mail them to me.....
Whatever the case is, Im upcoming some maintenance (25k since swap) and ID like to know what was done...
I talked to Doug on the phone, and he said he'd email them to me? Called week and half ago, and they said there was a big thunderstorm and computers were down.....
Hey! Did someone say 80s?(Resisting the temptation to post a photo of Don Johnson in a pastel suit.)
I would love to own a G50 where I could say "I'm coming up on 25k maintenance."
Q45tech
A certain 94Q had 2 tension rod bushings replaced on 9/17/04.109008 milesOn 8/01/03 while the engine was being swapped a cd player was replaced:88681 miles2 new engine mounts2 valve cover gasketsoil pressue switchwater pumpspark plugsthermostatALL belts4 rear differential bushings2 oxygen sensorsa rack boota transmission mount2 power steering hosesfront and rear main seals
On 09/04/03 the sunroof rail was replaced with good used and a wiring short was repaired in the trunk hinge area.
Sure there was misc small tweeks and things not listed but if it has been 110-88=28k since engine swapped.
elwesso
2007 BMW M Coupe
Car currently has 110k on the chassis....
Thank you dennis, much appreciated!!!
Were all the fluids replaced, and the fuel filter?
Looks like I'll need to start a new maintenance log!
DAEDALUS
Car: 1990 Infiniti Q45
Q45tech wrote:Sure there was misc small tweeks and things not listed but if it has been 110-88=28k since engine swapped.
Good thing T3 has a computerized billing system.
Q45tech
I'm sure the coolant, oil and ps was replaced. The fuel filter wasn't listed so probably not.Just start with everything fresh that way you know.
