Darius wrote:so what is the difference between AN and JIC then?? I thought it was in their flare angle, but I must be mistaken.
@Darius,"AN fittings are a flare fitting, using 37° flared tubing to form a metal-metal seal. They are similar to other 37° flared fittings, such as JIC fittings, which is their industrial variant. The two are interchangeable in theory, though this is typically not recommended due to the exacting specifications and demands of the aerospace industry. The differences between them relate to thread class (how tight a fit the threads are) and the metals used.
Note that 37° AN and 45° SAE fittings and tooling are not interchangeable due to the different flaring angles. Mixing them can cause leakage at the flare."
Behold the power of Wikipedia.
http://en.wikipedia.org/wiki/AN_thread
http://en.wikipedia.org/wiki/JIC_fitting
It appears that there is not a huge difference between -AN and JIC. Just one is industrial and one is Aerospace. JIC is more for hydraulic applications (higher pressure). At least that is how I read it...
Modified by l0nestar at 12:44 PM 3/7/2008
