ATTN: anyone with lowering springs
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
superskunk
Car: '07 Nissan Versa S Hatch
'06 Nissan Murano SL
i was in my backyard looking at the V and then i saw this.... i dont know how it happend or how long its been like this... but im going to fix it.... so to all of you with lowering springs, be aware of this problem....
Modified by superskunk at 3:34 PM 7/9/2008
blindsnyper
Car: 2007 versa
how did you manage that
superskunk
i was smoking a cig in the backyard and looked at my rim and then noticed it... i dont know how long its been off.... im going to go outside and fix it in a couple of mins.
blindsnyper
Car: 2007 versa
why does mine look different?
Johniboi
Car: Versa
how do you think the lowering springs caused this?
Well on my front right side of my tires, whenever i turn i hear this moaning noise..which is starting to worry me so i wanna get that checked.
and yeah yur setup does look different, mines looks just like bind_snyper's
superskunk
oh cuz i took the picture with the camera turned sideways.... and i forgot to rotate it when i uploaded it
superskunk
there i fixed it.... now its facing the rite way....
superskunk
so i went to fix the problem, it turns out i have to take off the strut bar, and remove the strut just to get it to tie back into the strut.... easier said then done, turns out one of the nuts that ties the strut to the car is stripped.... now im waiting for the tool, from a coworker so i can take it out and fix the problem.... oh yeah i had to take off the widshield wipers and the plastic cover again... i guess this time i will use thread locker...
Red Devil
Car: 1990 240SX w/t SR20
2008 Nissan Versa SL
You mean a mod not designed for the vehicle can result in unwanted damage? Weird.
superskunk
what? im lost here, do you even know what im talking about here?
Red Devil
Lowering your car caused one of the tie rods to pop off, correct?
shiryu0
Car: 2008 Nissan Versa
thats the sway bar link thats loose, not a tie rod...........
superskunk
funny i thought that was a sway bar.... how did it come off? any ideas?
t19uz
superskunk wrote:funny i thought that was a sway bar.... how did it come off? any ideas?
sorryyyyyy this is my stupid question, so the sway bar, is it accesories? or it came from the factory??
bulld0g
Car: 2007 Nissan Versa SL "Bulld0g Edition"
I think I found out what it is....I looked through my install pics and came up with these....hope they help
I think this is where it attaches to.
superskunk
yeah thats exactly what it was.... the easiest way to put it back on with out taking the hole strut out of the car is to use a jack underneath and lift it up untill you can put it back in....
groq36
Car: White 2008 Nissan Versa SL
oh wow. I was wondering what that was..a friend of mine put my springs on and i remembered that part being the last one he bolted. so it just came right off. i could be missin' something, but did that have anything to do with the springs or was it just an oversight?
t19uz
hmm i think overlooked.
superskunk
i think it came off with vibration... i had to replace the nut... 14mm.... picked up from autozone, also aplied thread locker, high heat.... im lucky, i didnt know when it had came off, but all the threads on the bolt were clean.... so it turned out to be an easy fix...
justmerging
Car: 07 Versa SL w/CVT Cuz I'm lazy
If it ccame off because of vibration, that would be an oversight, such as it wasn't tightened in the first place. I've had my lowering springs on for 30k miles now and I don't have any adverse effects.
The problem is not the aftermarket accesories ruining the vehicle, it is improper installation that causes problems. In the 15 years I've been driving, not one of my cars has been left stock. And I've never had any of the parts cause problems to any of the cars.
superskunk
thanks to everyone for the comments... good and bad.... anyways justmerging would you be interested in joing the socalversaclub? oh and how do you like the eibach springs?
justmerging
shoot me an email at [email protected] with details about the club.
I'm pretty limited on time but I'd like to help out/participate whenever I can.
Return to “Versa Technical Discussions”
