You can shred anything if it is not tuned or setup right.MeanGreenS13 wrote:and i would bat my eyes twice if an oem gakset held up to 20+ psi and an extra 75shot of spray at 1800psi bottle pressure... that gasket would shred dude, IVE DONE IT!
wire ringing the block is old tractor technology. screw that.MeanGreenS13 wrote:i was referring to pulling the motor out with these guys suggesting i ring the block when its already in the car... thats just the dumbest suggestion anyone could make at this point
When I see the word veteran used I just think of old and unreceptive to technology. A well fitted steel gasket solves all the issues that wire ringing does in a much simpler and structurally superior way. The wire ring is there to stop the fire rings moving, on a steel gasket there is no composite pressed fire ring so it CANNOT move. Things move on.dash wrote:A wire ring + cheap gasket is definitely something I'd try on a CA18 if my adventures ever come to that.Some veteran aussies use the exact method.
It's a theory I've looked at a lot actually. I've had and seen too many engines melt pistons and do permanent damage before the HG blows to but much belief or relaince in an inferior part. When you're dealing with the higher cylinder pressures, and levels of vibration (which is what will disturb the seal on a standard gasket) a composite gasket is too much of a compromiseks13 wrote:sideways, and others....what do you guys think about the headgasket being the weak link as another member mentioned? Rather pop a gasket that break a ring land/ring/piston etc.
"veteran" in the sense of street cars running in the 30psi region.Not a place for 'the inexperienced'.Some applications had no steel gasket available, others simply preferred the O-ring/stock gasket.sideways danny wrote:
Hmmm....I'm wondering if removing those sturdy oe brackets from the intake, has an adverse affect on the head/block/composite seal ?Folks usually discard these. You'd think Nissan didn't go thru all that trouble to 'triangulate' the lump, for no reason, eh.sideways danny wrote:When you're dealing with the higher cylinder pressures, and levels of vibration (which is what will disturb the seal on a standard gasket) a composite gasket is too much of a compromise.
Hey Brother, you bring up a valid point, but I'll be the first to admit to ditching them ASAP! I just haven't seen the effect of the absence of those brackets, but it's not to say that it can not and/or have not affected others' projects. Maybe the boost gods feels sorry for me and let me get away with bloody murder (some short-cuts). Note to CA forum: Stop ditching parts you .dash wrote:Hmmm....I'm wondering if removing those sturdy oe brackets from the intake, has an adverse affect on the head/block/composite seal ?Folks usually discard these. You'd think Nissan didn't go thru all that trouble to 'triangulate' the lump, for no reason, eh.
